tarbash2024
- Apr 21, 2024
- 4
- Joined
- Apr 21, 2024
- Messages
- 4
I bought a predator 9500 inverter generator a few years back.
I am running into a problem with it, it does not run my 240 AC appliance.
I tried measuring the voltage using a multimeter, but the readings fluctuate
all over the map. Same for the 120 ac outlet, even though
i can run power tools using that outlet.
Is this normal for inverter output. What is the best way to measure RMS voltage output of
the inverter. The sam multimeter gives steady readings for my utility power and another generator, although
that generator does not have an inverter.
