VCR S-VHS JVC HR-S9500 Switches off after 6 seconds
G
gudule
Loads cassete ok, loads tape ok and switches off after 6 seconds. Eject ok
I cleaned the mode switch. I checked the end sensor,they are ok.
Resoldered the end sensors , led, and the vcr plugs/sockets.
After all this , it is still doing the same problem. Then it started to
work ok, pb was ok. Then I installed the cover and it would not work
anymore, same problem ????
Anyone can help me with this problem ???
Réjean
SERVICE ELECTRONIQUE SATELLITE
QUÉBEC
S
sofie
does it go into PLAY mode? does the TU reel turn?
John
As soon as the tape loads press pause.
If it sits in pause ok then you probably have a reel sensor problem.
If it still cuts out you probably have a drum rotation detection fault or
tape loading is not complete.
John.
jomiservice
This a typical problem in JVC VCRs
Take off the power supply module and replace all the electroliti
capacitors.
Jom
M
Mark D. Zacharias
Take off the power supply module and replace all the electrolitic
capacitors.
Jomi
I think a HR-S9500 has the SMPS on the main board, and since it's not
enclosed, the caps don't tend to go bad as often.
Mark Z.
B
Bob Shuman
If the power levels look correct, then remove and thoroughly clean and
reassemble the mode switch.
Similar threads
W
Replies
10
Views
3K
William Sommerwerck
W
V
Replies
43
Views
6K
Vincent Poy
V
L
Replies
Views
1K
Mark D. Zacharias
M
R
Replies
Views
2K
Andy Cuffe
A
