- Joined
- Nov 28, 2011
- Messages
- 8,393
That's how Thevenin equivalents work. Here's a simple example that should make it clear:Yes thanks for the response, it absolutely makes sense. One other thing though if I may ask, if we pretend R2 isn't there, why are we calculating total resistance of R1 and R3 as though they were in parallel, afterall when we pretend that R2 is not there, aren't R1 and R3 in series and total up to 400 ohms instead of 75 ohms??
. . . . . . . . . . . 2k . . . . . . . . . . 2k
+10V -----------\/\/\/\/\/--------------\/\/\/\/\/------------ 0V
. . . . . . . . . . . . . . . . . . ------ point "X"
There are two 2k resistors connected in series across a 10V power source. They act as a voltage divider, so point "X" will sit at +5V (assuming nothing else is connected to point "X" to affect the voltage).
This circuit has a "Thevenin equivalent" - it is equivalent to a +5V voltage connected through a resistance to point "X". This resistance is calculated as the PARALLEL combination of the two resistances. 2k in parallel with 2k is 1k.
The Thevenin equivalent of the circuit above is:
. . . . . . . . . . 1k
+5V -----------\/\/\/\/\/--------- point "X"
