2 Stage BJT (Potential Divider Biased) design
bratva
Apr 20, 2016
Apr 20, 2016
Hi all.
I require help designing and analyzing the following using the parameters given below:
Stage 1 - (Potential Divider Biased) Common Emitter: 2mA ≤ Ic(q) ≤ 15mA
Av (CE) = 2 ≤ |Av| ≤ 6 (with RL connected)
Stage 2 - (Potential Divider Biased) Common Collector: 5mA ≤ Ic(q) ≤ 10mA
Av (CC) = 1 (approximately)
*Also, RL = RC
*Both Stages must be mid-point biased
*Power Supply = +15V
dorke
Jun 20, 2015
2,342
Jun 20, 2015
2,342
Welcome to EP.
What is the problem you have with designing those 2 circuits?
They are straight foreword,is this homework?
One important issue missing is the frequency range required.
and another issue is the value of RL .
