Please help in identifying this (possibly) tiny JST connector
Alterego
Sep 28, 2018
10
Sep 28, 2018
10
Have been trying to repair my RamboTech old headphones. Found out this connector wire from the grip pins has gone loose. Can try to repair it is as well, however not sure will it work or not.
Can someone please identify the model number of the white connector in the picture (boxed for identification) and a possible place (Ebay or elsewhere) where I can find some. Will try to reinsert the bare wire in the prongs of a new connector for strength and durability.
Thanks for the responses.
Alterego
Sep 28, 2018
10
Sep 28, 2018
10
I usually try to buy them with the lead already connected.
Very very fiddley to get the connection satisfactory otherwise.
https://www.ebay.com.au/itm/5-Sets-...845885?hash=item1f0ed54c3d:g:hKwAAOSwnfRb~Tqr
I would agree with you on this. Would plug it in the male connector on one side, and would sold the bare wire ends on the other side on the ear speaker. Only problem is getting the exact shape of the female plug connector. Have had a look at the link you shared from Ebay and the other related products, and unfortunately am unable to find an exact match. All the plug connetors are kinda squarish or rectangular, this one is a bit wide at the bottom and then narrowish rectangle till the (inserting end which goes in the pins).
On a lookout for it, please share if you would be able to find one.
Thanks for the reply.
Bluejets
Oct 5, 2014
6,958
Oct 5, 2014
6,958
https://inhelume.com/products/sh-1-...-4-5-6-pin-leads-100mm-28-awg-wire-pcb-header
