Jacques St-Pierre
I am designing a small system to measure water contaminant using light going
trought the water.
So on one side I use a LED drive by a constant current source, and on the
other side a Cds (Photoconductive Photocells).
Without any water, just in air, I can not adjust my circuit because the
resistive value of the Cds is constantly changing. So I remove all my
component and simply connect the Cds on a ohms meter.
The resistance value of the Cds change with variation in light condition as
is suppose to do, but instead of stabilizing around a value, the resistance
value is slowly going up, and it's doing so as long I wait to check it.
So because of that constant rise in value it's impossible to set any form of
calibration to my device. I need something that give me a resonably stable
value for a constant light source.
Do someone know why that append? Anyway to stabilize the resistance value?
Any other low cost sensor element to suggest?
Bye
Jacques
trought the water.
Bye
Jacques
