need small PAL with SR latch
Discussion in 'Electronic Design' started by colin, Jun 24, 2005.
  1. colin
    colin Guest
    I need a small prgramable logic device with a couple of SR latches,
    however they all seem to have D types or other type of latch on the macro
    cell with a global clock/set/reset, exept for some of the realy big ones.
    Ive looked through all of the ones that Farnell sell, and although I
    could obviously feed back an output to make an SR latch this wouldnt be
    ideal, any one know if there are any like this ?
    Only needs a dozen gates or so to do the job, could do with being fast
    as posible and in circuit programable etc.
    Colin =^.^=
  2. Joel Kolstad
    Joel Kolstad Guest
    Why do you say that feeding back an output (internally within the part) isn't
    ideal? With most of the smaller PLDs, the routing is pretty staightforward
    (and fixed!) so it's reasonable to just build your own using the AND-OR array
    within the part.
    I haven't use any non-in-circuit programmable parts in years now; I'm amazed
    that anyone still does.
    ---Joel
  3. The Xilinx SpartanXL had RS latch options in the CLBs, but it wasn't
    well supported. RS latches tend to cause timing headaches and aren't
    recommended. If you insist on RS latches the tools will infer one from
    VHDL, though will bitch loudly (at least Synplify would do both).
  4. colin
    colin Guest
    I estimate there would be 6 gates in the circular path as well as the
    loading of the output pin and grid lines, compared to a normal latch etc
    were there is a circular path of 2 gates with minimal loading. there would
    be a significant diference in speed/generated noise. Im trying to acuratly
    measure relative edge timings so the faster the better, bit like in a type
    II phase detector, except I found that doesnt work quite the way I expected
    as it is indeterminate if a waveforem is 90' or 270' out of phase. a simple
    xor detector would not alow as much sensitivity.
    I havent designed in any pld's for ages :)
    Colin =^.^=
  5. Joel Kolstad
    Joel Kolstad Guest
    Hi Colin,
    Some (possibly even most) parts have the ability to route the AND-OR array
    output back to the input side of the array again prior to the output block
    (typically this is used when they need to use more product terms than a single
    block can provide), and hence the loading of the output pin has essentially
    zero effect.
  6. Joerg
    Joerg Guest
    Hello Colin,
    I have designed out a lot of PLD for ages. Usually because they were
    expensive power hogs ;-)
    Regards, Joerg
  7. colin
    colin Guest
    what sort of devices did you replace them with ?
    Colin =^.^=
  8. Joerg
    Joerg Guest
    Hello Colin,
    Mostly with logic. In TSSOP the total real estate usually didn't grow
    but the cost was substantially lower. Plus the stuff didn't become
    obsolete a few years later.
    Sometimes the replacement was a cheap uC, other times a small LUT ROM.
    Regards, Joerg
  9. colin
    colin Guest
    aha i see,
    all i need is 1 nor, 1 nand, 1 sr latch, 2 xor, and a 1 bit tri state
    buffer, I could probably do it with a very fast LUT too but im not sure if u
    can feedback data lines to address lines reliably unless its clocked,
    otherwise thats a few diferent packages even if i try and convert some of
    the gates etc.
    A gal16v8z doesnt seem to consume much power unless they are hiding it well
    in the data sheet, oh wait thats in standby, at 10mhz its 55ma but im not
    pumping the clock line so maybe itl be a lot lower.
    Colin =^.^=
  10. Joerg
    Joerg Guest
    Hello Colin,
    Look at "Normalized Icc versus Freq" in the lattice data sheet on page
    19. It doesn't exactly appear to be a static CMOS behavior, there is a
    pretty stiff pedestal at 0MHz.
    What really irks me and is acutally often the main reason why I do not
    use GALs in my designs is the cost. Your 16V8Z, for example, gobbles a
    whopping three to four (!) Dollars per chip. No thanks. I can do that
    with logic for 50 Cents or so and chances are pretty good that my
    clients can buy exactly those same logic chips 15 years from now without
    any problems. From half a dozen sources.
    Regards, Joerg
  11. colin
    colin Guest
    yes there seems to be lots of difernt parts of the same sort, maybe they
    would be cheaper otherwise, or if you didnt keep designing them out HA ! the
    cheapest I found was 70p @ qty 100
    Maybe it has an internal clock running for some reason ? bias generator
    perhaps ?
    I wonder if the lattice software predicts supply curent im just tryin to get
    to grips with that softwar enow.
    Colin =^.^=
  12. Joerg
    Joerg Guest
    Hello Colin,
    If that is 70 Pence (UK) I'd still consider that expensive.
    Maybe but when something gets warm without doing much I don't like to
    design it in.
    I was always a bit afraid that someday an assembly house messes up PAL
    placement. Others (the PAL aficionados) told me that I am too paranoid
    about that. Then came that day. Almost 100 boards totally non-functional
    because they had slipped a number on the SMT placement. The boss there
    almost went ballistic.
    Regards, Joerg
  13. colin
    colin Guest
    thanks,
    Im trying to get to grips with some of the software from the manafacturers,
    I tried Altera's Quartus II and that seems realy nice and easy to use, and
    has no trouble taking my schematic with an rs latch. however they only do
    devices many times larger than what i need. with about 100 too many pins!
    I tried Lattice and finding this awkward to use but managed to create a
    schematic with an rs latch, I was puzzled becuase I couldnt relate this to
    the data sheet, however I realise now this isnt what I need as it is using a
    D type latch (with a clock wich i had ignored), so I reverted to using 2
    gates to do the RS latch function.
    Im confused though becuase it seems to have created a gal16v8 but with what
    apears on the chip report to be negative logic outputs wich isnt what i
    asked for or want.
    maybe it would be better to enter it in vhdl ?
    what would be an ordinary rs latch as oposed to a equivalent of a clocked D
    type latch?
    Colin =^.^=
  14. You can easily do an RS latch in a GAL16V8
    in CUPL it would look something like this :
    q=q & !reset
    # set;
  15. colin
    colin Guest
  16. John Larkin
    John Larkin Guest
    For a 22v10 sort of architecture, an RS latch is just
    Q = Q * \CLR
    + SET
    which is just one macrocell.
    John
  17. keith
    keith Guest
    Yeow! I have no experience with Altera, but it sounds like you have
    something seriously wrong with the setup.
    The D-flops often have both Sets and Resets, but often they can't be
    connected into the routing matrix, or only one can at a time. You are
    asking to do something that the manufacturers try to prevent you from
    doing. I had similar problems trying to make a D-type latch. While the
    two gates should work, the problem is trying to convince the software that
    this really is what you want. It will try to prevent you from doing it.
    I'm confused. You asked for a 16V8, or it chose for you? You may have
    IOB issues as well. Getting the IOB right can be a PITA.
    Perhaps something like...
    (r,s, and q are standard_logic or standard_ulogic)
    SRLatch: Process (S,R) -- Set dominant SR latch
    BEGIN
    IF s = '1' -- Set is dominant
    THEN q <= '1';
    ELSE IF r = '1'
    THEN q <= '0';
    END IF;
    END PROCESS;
  18. colin
    colin Guest
    I think its just simply that the smaller Altera devices are listed as
    'classic' so I gues they dont do them anymore, the software for them 'Max
    plus II' is listed as superceded by the new software but that lists the
    smallest device as having nearly 100 pins.
    Yes I am getting the hint now that they dont want you to do something like
    this, I gues they feel clocked logic is more idiot proof, and that were all
    idiots or something and timing issues are to hard for us to sort out ... as
    it was I now realise the RS latch I thought I had selected was not the
    simple type i was after but a clocked version (ie synchrounous set/reset)
    and as I had tied the clock to VCC it kindly reduced it to nothing.
    Confusion abounds ...
    The lattice software asks you to select either 16v8,18v8 or 22v10 etc
    If I select a gal22v10 it comes out correct but not if I select 16v8,20v8
    etc.
    Im not sure what i need to do in relation to the IOB for the 16v8 that I
    didnt have to with the 22v10 ?
    I just let it chose the pin assignments.
    I also find that the OE wich can be 1 product term from the matrix is not
    able to cope with more terms, even if I asign the equation (a xor b) to
    another pin it still tries to use the 2 terms necessary to do the xor rather
    then use the term already generated, wich is a bit frustrating. Is there
    another software package that would be better than the one lattice provide ?
    Ah thanks, I was thinking that VHDL would alow you to enter devices from a
    library (like you would on a net list) but obviously not.
    So the compiler makes sure q doesnt change if s and r are low I gues ? I wil
    give it a try :)
    At least now ive got started in VHDL ...
    Colin =^.^=
  19. keith
    keith Guest
    Oh, *now* the light goes on. I thought your design came out with 100
    pins. Yes, FPGAs are going to have a lot of pins. ;-)
    Not necessarily more idiot-proof, but clocked logic can be simulated
    and timed. Asynchronous logic and loops in logic are nightmares.
    It will. You can instantiate devices directly, much like a text version
    of a schematic. You need to know what is in the library though. I try not
    to do this because it messes up the VHDL and makes it less portable. When
    I find it necessary, I keep all such instantiations in seperate files and
    mark them as being technology dependent.
    If R and S are low, neither IF clause is triggered and the data is
    whatever it was. If either is active that clause is triggered and the
    appropriate THEN is executed. One key point here is the sensitivity list
    in the process statement "(s,r)". This triggers the process to be
    evaluated whenever R or S changes state.
    I found VHDL, at least the synthesizable subset, to be very easy to learn.
    Much of the difficulty is in knowing what synghesis is going to do with
    your source code. Synthesis matches templates, so your job, should you
    choose to accept, ;-) is to learn what templates turn out what logic.
  20. colin
    colin Guest
    :D
    Its amasing just how many pins some of theses devices have, and with oudles
    of gates too and 400mhz clock speed etc, and yet they stil dont consume that
    much more power than some of the small ones.
    Im realy tempted to try and do something neat to do with all those pins but
    cant think of anything right now.
    Yes its easy to verify setup times are met with clocked logic as everything
    just adds up between the edges.
    Metastable states in asynch loops can cuase nightmares but they still have
    defineable boundries, the latches in the macro cells have internal async
    loops hence the setup and min clock width timings inorder to avoid
    metastable states but it is much more controled as they will only have 2
    adjacent virtualy unloaded gates in the loop.
    In logic wich has numerous feedback loops all the possible circular paths
    can be very complex and hard to ensure metastable (or race conditon) states
    are avoided, but as the theory is reasonably simple a computer should be
    able to handle the complexity, but it seems the tools are made to do it the
    easy way.
    However it seems high speed clocks accross large chips are cuasing problems
    and theres interest in using more asycnhrounous techniques such as mixed non
    synchronised clock systems however these seem to cuase as much problems, if
    you could make a microprocessor internaly completly asynchronous (with of
    course suitablly generated handshaking for every movement of data) it would
    avoid clock issues altogether.
    ah yes of course, il have a look to see if there are any asycnhrounous sr
    latches already there.
    That reminds me of trying to use high level languages in multi tasking
    embeded systems.
    Colin =^.^=
