Nightmare2828
- Jun 17, 2015
- 2
- Joined
- Jun 17, 2015
- Messages
- 2
So, we are using a simple circuit to test the conductivity of of bunch of wires passing Inside a steel tube. We simply connect each ends of the wires into a circuit with a 9V battery and a LED per wire. That thing worked fine until there was apparently an unsheathed wire Inside the steel tube. The LED worked fine, so we were unaware of the current running through that steel pipe until later...=/
Since I'm not too familiar with electricity, I wanted to know if I could simply use a LED and make both legs in contact with the steel tube/plate to detect a potential short like the one described above. I.E. would the LED attached to the steel tube light up if an unsheated wire plugged to the 9V battery is in contact with the steel tube.
Feel free to ask questions if the situation explained is not clear.
Thanks in advance!
Thanks in advance!
