need help for this SMPT
zezo
Dec 5, 2010
16
Dec 5, 2010
16
i want to buy a switch-mode power transformer with a(16-8-24)volt can any one help me to find it
Mitchekj
Jan 24, 2010
288
Jan 24, 2010
288
Most all SMPS transformers are custom jobs, as such you'd need to wind it yourself (which would be the epitomy of non-trivial) or find something close enough that you can modify your circuit to work with.
Those are odd voltages, btw. Which is which (primary/secondary/aux)?
14,268
14,268
Compact 24V SMPS units are readily available with currents up to 10A I use them regularly... there are plenty of them for sale on the net
http://www.ekt2.com/_files/36 SMPS 24V 10A.pdf
you would soon to be able to use it to produce your 24V and using external regulators to produce your 16V and 8V rails.
As Mitchekj suggested, you are not likely to easily find a ready made unit with those voltages out.
cheers
