F
FyberOptic
I'm having a bit of a quandary. Since I'm still somewhat of a
beginner, I hope somebody more experienced can help me out!
I have three TTL logic chips, with one input on each one all connected
together to a single input signal. When that main signal wire is
connected to ground, the logic chip signals are all low as expected.
When I remove the ground connection though, they seem to all go high
on their own without being connected anywhere (aside from to each
other). This isn't my problem exactly, but I'm curious if someone can
explain it.
So I need a pull-down on that main input signal to keep the inputs
it's connected to forced low unless a high is explicitly introduced.
The main input signal itself will be connected to a pin coming out of
a chip elsewhere, which is switchable between being an input and
output. At startup, that pin is an input, so it's not outputting a
low like I want, hence the need for a pull-down.
Where the actual problem comes in is that when I add a "normal" pull-
down resistor value between the input signal and the ground, it
behaves as if it's not connected to ground at all. I've tried a few
different ones, from 100k, to 50k (didn't have a 47k), down to 4.7k.
I couldn't figure it out. Then finally I tried a 1k, and it seems to
properly pull it down low. Keep in mind that this isn't even
currently connected to the other chip I mentioned which will default
to an input at startup, this is just the input signal being connected
to ground or left floating. Is having to use such a low pull-down
resistor because I have three inputs connected together? Is there a
resistance inside the IC I'm not taking into account when connecting
it up like this? My assumption is that a "normal" 10k-47k pulldown
value assumes only a single input is being connected to. A possible
worry I have though is that the 1k resistor is kind of low and could
be wasting power (since it will be able to run from batteries), but I
dunno.
I'd appreciate any light anyone can shed on how these things work!
explain it.
dunno.
