MMC / SD Spi Interface
Discussion in 'Electronic Design' started by Ezmeralda, May 16, 2007.
  1. Ezmeralda
    Ezmeralda Guest
    Hello,
    what is the maximum possible speed on SPI Interface for MMC and SD
    cards?
    Is there any difference between the cards? Is it possible to do SPI
    communication
    with the new high speed rates defined ~50MHz or is the high speed rate
    possible
    via parallel interface only?
    Thanks!
  2. Donald
    Donald Guest
    Conversion of parallel to serial (SPI) is done all the time.
    The question is how do you want to do it ?
    Are you looking for an off-the-shelf solution or
    do you want to design, build, troubleshoot your own.
    donald
    PS: I have not seen a off-the-shelf parallel to MMC/SD device.
    PPS: Speed of download to an SD card is only part of the time involved,
    there is also internal burn timing to consider.
    good luck
