MMC cards in SPI mode
M
markp
Hi All,
Has anyone out there used MMC cards in SPI mode? I'm seeing a strange
problem in that I have two MMC cards with separate enable signals - if one
is enabled and the other disabled sometimes the disabled one will not
recognise a new command once it is enabled (usually returns 0x4, i.e.
invalid command). Retrying the access seems to cure it. Anyone seen anything
similar?
Mark.
M
Mark VB
markp said:
Hi All,
similar?
Mark.
Because you mention that the problem only occurs after being disabled, it
seems to me that you start sending too soon. Do you use CMD58 (Read_OCR) to
check that the initialization process has completed before sending the first
command ?
2nd Possibility: Datasheets mention that, when the card encounters a data
retrieval problem, in SPI-mode it will respond with an error, rather than by
a time-out as in MMC-mode. And because none of the errors actually
corresponds to that situation... So, does the problem occur with both cards
Mark Van Borm
M
markp
Mark VB said:
command ?
Mark Van Borm
Hi Mark,
Initial access is OK, the problem comes when the CS* is de-asserted and then
the other card is accessed. This seems to screw up the disabled card so that
when a new command is actually given to that previously disabled card it is
decoded as illegal. (BTW CMD58 doesn't exist!). The problem seems to be only
with one card, but a retry always fixes it. Strange.
Mark.
