Mitsu CS27303
T
Tom Knowles
This set when first turns (most of the time) turns on with no sound
no osd, good video,channel change.
When I push the menu button screen goes blue and that is all. Pushing
it again may restore it to its previous condition
Does this sound like micro processor trouble? I have read alot of
posts on this faq site about these sets having alot of bad caps.
Once in a while leaving it off for a day or two,(unpluged from
power.) it will come on working perfectly until menu button is pushed,
then it goes into the blue screen mode and when it is pushed again goes
into the above described action..
K
kip
How is the TV using just the remote control ?
kip
T
Tom Knowles
It acts the same, this model has no menu button on the front control
panel.
R
Rono
Mitsubishi T.V.'s are known for all kinds of bad electrolytic
capacitors, look closely, can cause many problems. Rono.
L
Leonard Caillouet
Every polar electrolytic cap needs to be inspected for leakage and any that
are in circuits relevant to the problems need to be ESR and capacitance
tested. You will find about a dozen leaky caps in this model. Don't bother
to do any real troubleshooting untill the leaky caps are changed, the board
is cleaned of residue, and repair to bad traces and connections is made.
Leonard
Similar threads
T
Replies
Views
907
Leonard Caillouet
L
N
Replies
7
Views
1K
Leonard Caillouet
L
E
Replies
3
Views
844
Leonard Caillouet
L
