Looking for a data sheet on this transistor ? from a ultrasonic cleaner powersupply
Natem600
Oct 22, 2014
1
Oct 22, 2014
1
I am trying to find the data sheet / replacement part # for this *edit* transistor ? well I think its a transistor.
Its marked LL 38 B, it's from the power supply in a Ultrasonic cleaner . Any help would be greatly appreciated.
0smmZIlQc5GGCJ
https://files.secureserver.net/0smmZIlQc5GGCJ
0sg8Ne1YNat9px
https://files.secureserver.net/0sg8Ne1YNat9px
0sMkOertcSnlIK
https://files.secureserver.net/0sMkOertcSnlIK
4,889
4,889
Well, at least the Base and Emitter connections are marked. Do you have any that more or less still work, i.e., the emitter-base and base-collector junctions measure okay? Maybe if you knew whether it was a PNP or NPN bi-polar junction power transistor you could try to find a substitute. Is there a schematic available for the ultrasonic cleaner, or can you trace one out (reverse engineering this is called)? The numbers marked on the device are probably lot numbers or refer to proprietary part numbers assigned to an ordinary commercial part. It may or may not have undergone special testing to pass specifications for its particular application in the ultrasonic cleaner.
14,268
14,268
Hi Natem600
welcome to Electronics Point :)
^^ I agree with this
and yes, unless you have a schematic or you spend time tracing out the circuit, then there's probably no way to figure out a suitable replacement
cheers
Arouse1973
Adam
Dec 18, 2013
5,178
Dec 18, 2013
5,178
Some ultrasonic cleaners use the now obsolete SJ9089A. It's alternative appears to be an MJ16018. If that's of any help.
Adam
