S
Sara
Dear friends
I used lm833 as a comparator because of it's high slew rate but the
problem is one of the
inputs comes from a detector- an analog signal which amplitude is 0 to
9V-.
The minimum is 0 but when I connect it to the input pin of opamp it
comes up about 0.5V -DC is added by opamp-and the operation of
comparing with about 0.5V intrfaces big problems .My circuit is a very
primary one with no resistances in the output.
Any idea how can I remove the DC from the opamp pin?
Thanks in advance
Sara
9V-.
Thanks in advance
Sara
