1-bit magnitude comparator.
Discussion in 'Electronics Homework Help' started by timmy1521, Apr 28, 2020.
  1. timmy1521
    timmy1521
    4
    Apr 28, 2020
    with the following outputs int the pdf file
  2. Harald Kapp
    11,009
    2,506
    What is your question?
    What have you done so far to solve the task?
    We will give you useful advice, but we will not do your homework. Only by solving the task yourself (with helpful nudges from us) will you be able to learn something - not from copying ready made solutions.
  3. timmy1521
    timmy1521
    4
    Apr 28, 2020
    i have managed to identify X Y Z being A.B', A'.B, A'B' respectively.
    Have slightly drown a circuit diagram but my doubt is on the relationship of Z is it supposed to be attached to the output of X and Y?
  4. Harald Kapp
    11,009
    2,506
    You can either define Z = f(A,B), as you did, or Z = f(X,Y) as you asked.
    Using the correct boolean operations both methods will produce the right output.
    The difference is in the timing: Assume some arbitrary runtime T for the calculation of a boolean function f(). What is the runtime for Z = F(A,B) expressed in terms of T and what is the runtime of Z = f(X,Y), also expressed in terms of T? Hint: X = f(A,B) and y = f(A,B).
    f() indicates the required boolean operation which are of course different for each output.
  5. bertus
    bertus Moderator
    1,489
    590
    Nov 8, 2019
    Hello,
    Here is the question in full:
    In the case A=B , both are either 0 or 1.
    Bertus
  6. timmy1521
    timmy1521
    4
    Apr 28, 2020
    yeah i was thinking in that question they have only picked were both are 0 to reference the relationship where A=B.
  7. timmy1521
    timmy1521
    4
    Apr 28, 2020
    ok thanks
  8. AnalogKid
    AnalogKid
    2,458
    705
    Jun 10, 2015
    Please post your schematic.
    ak
