LM324 datasheet with guaranteed sink voltages?
Joerg
Is there a really, really detailed schematic with guaranteed output
voltage limits versus sink current for the LM324? Most look like this:
http://www.national.com/ds/LM/LM124.pdf
Obviously, page 8 top left and the schematic show that one can get to
around 700mV above the negative rail at 1mA, one BE drop of Q13 plus the
saturation voltage (or close to it) of Q12. But no "hard" data anywhere.
Jim Thompson
You don't like page 4 ?:)
...Jim Thompson
Joerg
Nope, they only give one value there, how much current it is guaranteed
to drive when at 2V above the rail (10mA). Then uA value stated for
200mV isn't too useful, it just confirms that the current source
outlined in the schematic actually made it into production ;-)
10mA is pretty much at the point where the output device loses it. Not a
terribly useful piece of information.
Jim Thompson
WHY are you using an LM324... CHEAPSKATE ?:)
...Jim Thompson
Joerg
Umm, yes, that would be correct. Also the sheer number of suppliers, no
single-sourced parts around here unless there really is a compelling
reason. And usually there isn't a compelling reason.
BTW my Barricade needed a few power cycles over the last week. Not good.
What did you buy to replace yours? Tried a firmware upgrade before? Of
course the real cheapskate fix would be to plug it into a timer that
turns it off for an hour after midnight :)
Unfortunately I am going to need that printer port in there ...
Joerg
Jamie said:
Yes, Replace the caps.
I had some issues with my not to long ago.
Thanks. The electrolytics in the power supply inside the router? That's
kind of disappointing. Those routers used to be on the pricier side,
metal case, no wall wart and all that.
Jamie
Jim Thompson
All LM324's are not made the same. Remember my blacklisting Motorola?
Yep, Mine got like that more and more often over time.
Linksys BEFSR81
Yes. It was current, yet erratic :-(
Of
Yep.
Linksys makes a printer switch but, since the printers were wearing
out too, I bought printers with network ports... hp LaserJet 2015dn
and hp OfficeJet Pro K850.
We also have a Dymo LabelWriter 400, but it's local to my wife's
machine.
...Jim Thompson
Jamie
I'm on my second unit. the first one lasted about 8 hours. I unplugged
it from the service because a severe storm was coming in and I had just
got cable internet.. I went to work, my step son got home and thought he
was mighty smart!. I had other adapters there in the same area
unplugged. He didn't bother to look or care if they were correct of not,
all he wanted was the internet.. So, my first unit was a 5 volt DC
wallwart unit. I had a 12 AC wall wart there unplugged. so you can guess
which one went into the router.
Of course, it was all my fault which it usually is. I can say with
confidence, that boy does not share my gene pool.
The one I have now uses a 12 volt AC wallwart and the PSU is internal
with electro caps ..
Mine dried up and lost value... Caused unstable supply.
Joerg
I don't remember. What did their LM324 do to you?
I've read that some of the heat sinks in there are on the skimpy side,
at least I'll open it before I give it up. Mostly because of that LPT port.
Linksys BEFSR81
I've got a Cisco wireless here (I believe same brand as Linksys) that
also has a few CAT-5 ports so I can use it as backup should the SMC
croak on a busy workday. I try to have a backup for pretty much anything
essential.
Some firmwares supposedly could choke up when incomplete or deliberately
mutilated packets arrived, requiring a power cycle. At least that's what
I've read.
Got one of those as well (Brother MFC). Also has fax, copier and scanner
in there. The sheet feeder is really nice. Every year I had to copy a
huge stack of papers before giving them to my CPA, in case they get
lost. Now it's really easy: Put stack in MFC, hit scan to file button on
PC, go do something else. No waste of paper and 15 minutes later it's
all in one PDF file. Sweet.
machine.
We still write labels by hand, or I print, glue to blank label, then stick.
Jamie
Eeyore said:
Jamie wrote:
One of the milkman's ?
Graham
Well as I said, "Step son", He's more like his mother and
I won't go any future there.
Joerg
That must have been anotehr router. Mine has a SMPS built-in.
Joerg
Jamie said:
Really, they made like 4 different units supporting the same external
options.
Mine has 4 Eports and 1 WAN, 1 printer and 1 serial port for external
back up modem
Similar here except it has 7 LAN ports. But no wall wart. Also, the
whole metal box remains remarkably cool.
Jamie
options.
back up modem
Jamie
I would still considered looking at the caps. they are a common problem
with equipment that starts to slowly develope problems.
Btw, you're correct, we don't have the same one. oh well.
Jim Thompson
Extreme distortion. Reeked havoc with active filters.
essential.
I've read.
We have ~1000 Girl Scouts... we're neighborhood level now, and I'm the
neighborhood cookie manager ;-)
...Jim Thompson
Joerg
It reeked? SCNR ;-)
But yes, I would never use them for anything high fidelity. Only for
mundane stuff and since most circuits somehow end up in that category I
am probably responsible for a grand total of a large truckload in sales
of LM324.
That sure explains the label printer.
Jim Thompson
Jim said:
Jim Thompson wrote:
[snip]
machine.
Sure explains why NOT to volunteer ;-)
...Jim Thompson
M
Michael A. Terrell
Jim said:
Jim said:
On Fri, 18 Jan 2008 01:10:23 GMT, Joerg
Jim Thompson wrote:
[snip]
machine.
If your wife wasn't busy with her volunteer work she might decide to
spend more time keeping you in line! :(
prove it.
Member of DAV #85.
Michael A. Terrell
Central Florida
