Back in the day, my wife and I would do a walk-around inspection every month or so while one of us operated the controls inside the car: brake lights, tail lights, turn signal lights (front and rear), parking lights, courtesy lights, dome light, interior light(s), and head lights (upper and lower beams). It was fairly easy to tell, even in bright daylight, whether a light was burned out or not. I guess the current generation can't be bothered to do a walk-around, so
needs a dashboard indication to inform when a light doesn't operate.
@Nehmo, you can't disconnect anything on a modern automobile without the computer knowing about it and nagging you to put it back. And you can't disconnect the computer (which is distributed throughout the automobile) either, for then the car won't run. It won't even start. Maybe when the world runs out of fossil fuel everyone will switch to pedal power.
