John Fields
How'd it change from 30 mA to .035A?
Robert said:You should measure the voltage across a set of the LEDs at 30mA. Average the
value, and call it Vf. Then your resistor value should be a standard value
close to
R = (12 - 4 * Vf)/0.030
Negative R means you won't get 30mA out of it.
Since you are running the LEDs at 30mA, I'm guessing they will get hot.
Since this is the case, and since Vf is dependent on temperature, you should
let them heat up before taking the measurements.
You can build a 30mA current source as follows:
VCC
| | |100
1k | |<---| PNP
| LED
GND
created by Andy´s ASCII-Circuit v1.24.140803 Beta www.tech-chat.de
Hook the + lead of your multimeter to the collector of the PNP transistor,
and the - lead to ground, and put the multimeter into current measurement
mode. Adjust the pot to get 30mA. Then, hook up the LED between the
collector and ground, and measure the voltage at the collector (remember to
wait till it heats up). Thats Vf(30mA). It won't be exact, since the current
will vary depending somewhat depending on the voltage at the collector, but
it should be close enough for your measurement.
Regards,
Bob Monsen
Watson A.Name "Watt Sun - the Dark Remover" said:Robert said:You should measure the voltage across a set of the LEDs at 30mA. Average the
close to
VCC
| | |100
1k | |<---| PNP
| LED
GND
Regards,
Bob Monsen
I see no point in using the pot above. You know what current you want,
so just set the values for that current. Here is a circuit that will
limit the LED current to 30 mA, for wide variations in Vcc.
30mA current source:
VCC
| | | 22
| | | or
| '-' two 47 in
Q1 >| | parallel
PNP |--[470]--+
| |< Q2
+---------| PNP
22k| | --- LED
| | V ->
GND
c-X-vlachos@hot-X- said:Whoa! As if 144 resistors weren't enough!
Costas
VCC
| | | 22
| | | or
| '-' two 47 in
Q1 >| | parallel
PNP |--[470]--+
| |< Q2
+---------| PNP
22k| | --- LED
| | V ->
GND
