Jamie Morken
I am trying to make a circuit that will function so that when the power
is disconnected from the running device, and then the power is
reconnected, the device will stay turned off, until it is manually
turned back on with a push button switch. I was told that this could be
done with a latching relay and a DPDT switch, what would the circuit
look like for this? The device runs on 120VAC and draws 15Amps. I have
seen some latching relays on ebay for $1, but I can't figure out how
they would be used to build this circuit!
cheers,
Jamie
cheers,
Jamie
