Hi all
A I am not the greatest circuit designer.... can anyone help
I need a circuit that wll latch on at the press of a button, and then switch off at the press of second button.
There are a few 'rules' however....
The buttons are actually reed switches. So they are only NO contacts.
The circuit cannot draw any current while off.
The whole circuit need to be as low current drawing as possible.
It will need to switch a load of around 5A. So I planned to have it operate a relay.
I found several circuits that had a single on/off button, but they monitored the button for a press and I cannot have current drain while waiting for a button press.
The simplest idea was to just have a reed relay wired up to latch on, using its own contacts. But because the 'off' button is normal open, I have no way of breaking the feed to turn it off again (hope that makes sense).
I am sure there is a simple clever way to do this...
Thanks all
Thanks all
