nearest manual I have is the C330, and theres nothing helpful about
protection CCts etc in it. If it is almost the same unit the output is an
STK4141 which will run without it in circuit.- if this was faulty- the unit
would run but not cut in.
I suspect you may have more of a micro-micro not talking problem- CA-D4T
series very similar had issues with this. turned out to be the 64? pin
flatpack tape+ .. controller IC HD404xxx. display came on since front micro
runs but can't initialise with the other micro.
Another thought- the CD mech or tape mech/motor isn't jammed?
Can't find my C220 manual- not even sure if I had one.
Andrew
