Jelly bean N FETS
M
Martin Griffith
I've got to enbrighten some lumileds, for a brief period, say
50-100msec, using an external current limit resistor, say
350mA,running off 4 AA cells.
There are so many fets out there, which jelly bean?
SOT23 or PTH
Must be Joerge approved
martin
Joerg
SOT23 or PTH
2N7002:
http://www.onsemi.com/pub_link/Collateral/2N7002E-D.PDF
Pulsed isn't spec'd above 10usec and the 5sec rating is under 350mA so
if that feels iffy you might want to parallel two of them. Under $0.03 a
pop in qties :)
The Vgs spec for 4.5V Vgs is also a bit hokey. Up top it says 3ohms max
at 310mA, farther down they repeat that and state only 50mA. But they
handle high currents quite well. Depends on how often your 100msec
pulses happen.
Cordialmente, Joerg
http://www.analogconsultants.com/
"gmail" domain blocked because of excessive spam.
Use another domain or send PM.
M
Martin Griffith
2N7002?
John
I'd thought of that, but the max Rdson seems a bit high, 5to13R
depending on the wind direction when the fet was made ( fairchild
datasheet)
I'd like to make the external R determine the current, rather than
the fet.
There is enough room for a T0220, but that just seems silly to light
up a silly, but quite important, little LED
martin
S
Spehro Pefhany
SOT23 or PTH
martin
Why use an expensive MOSFET if a cheap BJT will do?
Eg. 8050 typical 0.28 Vce(sat) at 800mA (equivalent to 0.35 ohms) @
Ic/Ib = 10.
Best regards,
Spehro Pefhany
Joerg
datasheet)
the fet.
How about this one then:
http://www.onsemi.com/pub_link/Collateral/NTA4153N-D.PDF
SC75 meaning really tiny, but a tad over 10 cents.
M
Martin Griffith
Ic/Ib = 10.
Best regards,
Spehro Pefhany
wow, never heard of a 8050 before, got a URL? a quick google for
2n8050 just provided damn chinamart crap :(
martin
Joerg
datasheet)
the fet.
If you want to switch to an almost dead short check this one out but
it'll cost around 15c:
http://www.zetex.com/3.0/pdf/ZXMN3A01F.pdf
Also quite good at 11c:
http://www.fairchildsemi.com/ds/ND/NDS351AN.pdf
Now this one really ought to do it, at 12c:
http://www.onsemi.com/pub_link/Collateral/NTR4501N-D.PDF
M
Martin Griffith
2N7002:
pop in qties :)
pulses happen.
Thanks, just had a bad day with the UK/EU Farnell/RSwww search
enginzz, they have all this teknologeewhizzcrap and they dont have a
column of <RdsOn, or Vgs >5 etc.
Bad day, time for zzz, or a video maybe "Bad Day at Black Rock"
is applicable, or maybe the winavr help files (nooooooway)
Ugh
martin
Joerg
Don't expect "web designers" to learn, start your own parts wiki ;-)
Check out the other FETs from my last post, some pretty hot ones there
if the BOM budget can stomach 10-15c for the FET. Else it'll have to be
the old 2N7002.
C'mon, it ain't even midnight over there yet. Time for an eye on town,
maybe a cerveza (mas grande) or a Rioja.
Joerg
Martin said:
Joerge for President........................(of S.E.D)
Thanks, but no thanks. I've seen how presidential candidates were torn
to shreds in this here newsgroup ;-)
M
Martin Griffith
the old 2N7002.
I live in a sleepy town,even the kidz on mopeds have gone too sleep by
now, 23:31hrs, made a miserable tortilla, but the rioja is working
martin
Joerg
Phil said:
Now I wonder why they don't have SOA curves for a 20-V, 3.2-A MOSFET in
a SOT-23 package....probably because the curves wouldn't be
distinguishable from the Y axis... ;)
Yeah, they are meant for switching. Operate a bunch of them in linear
fashion for more than a few milliseconds and it's like the O.K. Corral
after Doc Holliday drew his pistol :)
Joerg
first hit for 8050 npn is SS 8050 fairchildsemi
Problem with those is they are not SOT23 and hfe can be less than 50 at
a few hundred mA Ic. That can become a bit tight if Martin wants to
drive it with a wimpy uC or something.
M
mpm
SOT23 or PTH
martin
Not to be a language cop or anything, but I don't believe "embrighten"
is a real word.
I looked it up in several online dictionaries because I thought maybe
I didn't know this one...
"embright" is a word (a transitive verb), and it does mean to
illuminate, but is considered obsolete. I could not find
"embrighten", or any other obvious variant, anywhere. FYI.
-mpm
Joerg
is a real word.
http://en.wiktionary.org/wiki/Citations:embrighten
But it does sound rightpondian, I've never heard it in the US. And
Martin mentioned he'd already had some rioja :)
H
Hammy
SOT23 or PTH
martin
Have you seen the the BSS138.
http://www.fairchildsemi.com/ds/BS/BSS138.pdf
Newark has the BSS138LT1G for 0.04 cents small quantity SOT-23.
Another possiblity may be the NTS4001.
10 cents from Newark sc-70
http://www.onsemi.com/pub_link/Collateral/NTS4001N-D.PDF
I have about fifty of each,easy drive requirments.
S
Spehro Pefhany
Fairchild is one source, but they are generic and very common in
designs for offshore manufacturing if you don't need a very high Vceo.
TO-92 like the 2N7000. The "D" beta bin is only marginally more
expensive.
Best regards,
Spehro Pefhany
