John Fields
Well, I did - do you think I'm stupid?
Not so far
The problem is, the measurement was automatic, and since there was
short-circuit somewhere (presumably in parallel to the supposed
resistor), the voltage was zero across the measurement points even
before the resistor was stolen. The current is of course measured the
proper way.
I'm not trying to be insulting, but would you mind explaining how the
current was measured?
The software computed resistance by Nick's rules and hence never noticed
anything unusual.
Nick's rules?
I'm in the dark about that. Clue me in?
Unless E=0 too, in which case the result is 1 (says Nick).
On a short circuit you can detect no voltage, but you can measure a
current.
E 0
R = --- = --- = 0
I I
This leads to a contradiction when E=I=0.
So it would seem, but a short across the resistor would still have
resulted in a voltage drop across the resistor equal to the parallel
resistance of the resistor and the short multiplied by the current
through that parallel resistance. Since there's no such thing as a
perfect short and the resistance of the resistor was known beforehand,
the "short" and the anomalous current (which you said you measured)
through it should have pointed to either the resistor failing shorted,
an external short developing across the resistor, or some dirty
bastard stealing the resistor and putting a short across where it was,
no?
How much was that resistor worth, anyway?
