Wow...It costs thousand!! if converted to RM..I will use my lecturer's Oscilloscope first
How about Logic Probe. Its cheaper. I'm sure you can afford this.
http://clarkson-uk.com/555-timer/operation/frames3.html
Delay-On monostable circuit..I have built it..My question is why they connect a diode to it ?
Hmmm. It does'nt make sense to me. Diode was reversed biased and this will not do anything w/ + 1/3V VCC.. That is, capacitor was already charged and Timer Output was High voltage Level to control something.
Probably a discharge path for the capacitor if Timer was power off.
http://clarkson-uk.com/555-timer/operation/frames3.htmlMy question is why they connect a diode to it ?
My guess is that it will allow the capacitor to discharge via the 555's voltage divider when power is removed.
Now I feel dumb for not posting it, I knew it after all
how ? charge flow from where to where?
Discharge current path
Your arrows are around the wrong way
Ha ha ha
