John S
Ask him!
In usually start with Xc and Xl around 50 ohms. Seems to work, usually.
Yeah, that's better. It becomes a sine wave and the Fo is 9.78Mh for a
calculated tank of 10MHz.
Ask him!
Clearly you fucked up >:-}
Hint, Zo = Impedance of the tank at resonance.
I apologize if I'm using too advanced engineering terms for you guys
I promise I'll try to be nicer if Larkin and John S promise to try to
be smarter >:-}
...Jim Thompson
When you are designing a circuit that requires tuning, most engineers
should be thinking in terms of the tank's resonant frequency, its
impedance at resonance, and its Q... I do. So, during the development
of that model airplane RC chip (I mentioned it here before) I whipped
up a template for a tank...
REFDES = TANK?
TEMPLATE = L^@REFDES %pin1 %pin2 {@Zo/(6.283185*@Fo*@Q)} \n
C^@REFDES %pin1 %pin2 {@Q/(6.283185*@Fo*@Zo)} \n
R^@REFDES %pin1 %pin2 @Zo
PART = TANK
SIMULATIONONLY =
Fo = 10Meg
Zo = 1K
Q = 10
where Fo, Zo, and Q are selectable parameters.
(Users of other Spice variants should be able to easily re-write this
"template" as a subcircuit.)
I also did it for tapped tanks, both L-taps and C-taps.
Why do I have to be constantly recalculating L, C and R values, when
PSpice will do it for me automatically?
I can even have PSpice list the L, C and R values in the parts list,
if I want.
The only reason I can see for Larkin's consternation is that the
method went right over his head, and sycophant John S "proudly"
announced, "Well, Jim didn't furnish L and C values".
Start acting like engineers, folks. Instead of trying to label me the
"buffoon", you should be asking yourself why didn't you understand it,
or is it that your only intent is to be assholes? I think the latter.
...Jim Thompson
Phil Allison said:"John Devereux"
** Doesn't the UHF band start at 300MHz ??
And how about a part number or two for the JFET ?
"Phil Allison"
Does it?
Can't remember for sure, it was 20 years ago. J310 I think?
Yeah, you got that right, people are learning..Jim said:Someone doesn't know how to run a transient analysis on an oscillator.
Was that John S who said it doesn't oscillate in LTspice? Shame on
you!
Liar, liar, pants on fire. I'm trying to be helpful and you keep
trying to stick your nose up my dog's butt.
The discerning student is learning from my posts. But you're not ;-)
Why don't you go sit in the corner, suck your thumb, and STFU?
...Jim Thompson
As long as it doesn't give you the Clapp.
No Larkin that is you.You flatter yourself, old man... because nobody else will do it. You have made
yourself the group buffoon.
It's not if you stick to the KISS principle, for example...
http://www.analog-innovations.com/SED/Primitive_LO.pdf
...Jim Thompson
The 1648 is a nice IC! Does this structure have any advantage compared
to the cross-coupled pair with the tank across the collectors -which I
have used quite successfully to make quick-and-dirty oscillators from 1
to several GHz?
[Schematic is unclear, but you know what I mean ]
R R
*----TANK----*
C---- -----C
B--- X ---B
E E
Re
GND
There are variants of this, most notably with L/2 instead of each of the
R and the cap between collectors. They seem to be very popular in
integrated VCOs nowadays...
Pere
On Sat, 8 Jun 2013 13:50:45 -0700 (PDT), "M. Hamed"
Hello the most knowledgeable electronics group on earth!
I am trying to build a few LC oscillators for experimenting with mixers. I do not want to use Crystals, Frequency Synthesis, DDS, etc. Let's say 2 MHz and 100 MHz. I don't know where to start!
I have a few RF books and the treatment of oscillator can be one of the following:
1- Too much theory on the analysis of oscillator circuits, phase noise, IMD, etc. No circuits to build. Just demo circuits for illustration, sometimes only the small signal model.
2- Circuits to build but designed at very specific frequencies with very specific components. Very little on how to generalize things into different frequencies. (The ARRL handbook 2010 and Experimental Methods fall under this).
3- Books that give me a design procedure with S parameters but I can't find any S parameter files for the devices I'm interested in using.
4- Cookbooks that have the same problem as (2).
Why is it so hard to build an oscillator at an arbitrary frequency?
...Jim Thompson
to several GHz?
R R
*----TANK----*
C---- -----C
B--- X ---B
E E
Re
GND
Pere
Jim's circuit has one end of the tank at RF ground, which can have advantages,
like when using an asymmetric trimmer cap or a varicap. And it's easier to
extract the output signal. Q is potentially higher, too, since it doesn't have
those R things across the LC.
The only thing I did not understand was your reference to Zo. I've never
seen that applied to a tank circuit.
I didn't know it had a specific name ;-)
I just found the impedance method useful when designing, rather than
just pulling some number out of the air, like 50 Ohms.... >:-}
Dynamic?
There is a plot file after the .asc file, which plots Zd.
If someone is not already credited on this, you should be.
Many times the result is a very poor, inefficient one at that, as
compared to dedicated (intended to be such at design time) oscillator
circuits.
I associate motional with motion, like a quartz resonator.
What it all boils down to is: keep the L/C ratio as high as possible.
