I have a broken linear encoder that I want to repair...
Dan Boy
Jun 12, 2015
14
Jun 12, 2015
14
Hi, I allowed some coolant fluid get into my linear scale and now the read head won't work. I am guessing that the fluid, mainly water based has broken some of the components.
I hope someone can them and tell me how to test and or replace them.
Minder
Apr 24, 2015
3,478
Apr 24, 2015
3,478
Is it optical or inductive/capacitive?
It could be cured by cleaning and drying, especially if optical.
Use de-natured alcohol on the scale.
M.
Dan Boy
Jun 12, 2015
14
Jun 12, 2015
14
I am guessing but I think it is optical. It reads lines printed on a piece of glass. Do you mean to clean the glass or the component?
Thanks Dan.
Dan Boy
Jun 12, 2015
14
Jun 12, 2015
14
Just gave it a clean, both the glass and the sensors. A little dirt came off but it still doesn't work. Can I test the components on the PCB?
Arouse1973
Adam
Dec 18, 2013
5,178
Dec 18, 2013
5,178
Hi Dan Boy
Can you take some better pictures please they are a bit unclear. We can't see the extent of the damage
Adam
Dan Boy
Jun 12, 2015
14
Jun 12, 2015
14
Is this any better, the thing is so damn small. I can test the components if I know what reading I should be getting.
Arouse1973
Adam
Dec 18, 2013
5,178
Dec 18, 2013
5,178
Those three resistors look like they could do with a re-solder. One looks like its moved quite a bit. Or not centered during reflow, an indication of not enough solder or too low heat.
Adam
Minder
Apr 24, 2015
3,478
Apr 24, 2015
3,478
Is that the read head itself? The part the moves over the scale? It does not appear to much in the way of electronics on it, if optical there should also be opto RX TX and a part of a grating similar to the head, Unless it is capacitive?
M.
4,953
4,953
That middle resistor definitely tried AWOL during the wave soldering.
Perhaps a good clean with isopropyl (using ear buds / qtips).
And make sure the board is completely dry.
Martin.
Dan Boy
Jun 12, 2015
14
Jun 12, 2015
14
Before I break out the soldering iron, can I test the resistors to see if they have failed?
There are more boards to this read head but this seemed the most likely one to fail as it was in the coolant.
Thanks Dan.
4,953
4,953
Hi Dan, you can't really test a resistor without de-soldering a leg. To do so in circuit will give false results.
First clean all boards and let them dry COMPLETELY.
The water based fluid could still short circuit even when you think it is dry.
Heck, I should know, my computer mainboard only got 1/4 of a can of beer.
and wouldn't work for a week. I am typing to you now on it...
Coolant is corrosive and gels. Clean all boards thoroughly as smd's can retain moisture underneath too.
Martin.
Minder
Apr 24, 2015
3,478
Apr 24, 2015
3,478
What make of scale/DRO is it?
The two small bearings at right angles indicates this is the read head, it is imperative for both type that alignment is maintained.
I don't see any optical head there, so is it possible capacitive?
I have always found that they are fairly impervious to coolant etc, that a scale/head clean could not overcome, particularly for the optical type.
M.
Minder
Apr 24, 2015
3,478
Apr 24, 2015
3,478
You can get electronic cleaner in an aerosol can from most electronic suppliers, get the non-residue type, alternatively use de-natured alcohol.
M.
Minder
Apr 24, 2015
3,478
Apr 24, 2015
3,478
They almost appear similar to fuseable links or contact pads?
Do they all measure the same continuity?
M.
Dan Boy
Jun 12, 2015
14
Jun 12, 2015
14
I can't get any reading off them at all. On the other side there is a glass eye.
Minder
Apr 24, 2015
3,478
Apr 24, 2015
3,478
They most certainly are the IR LED's (or could be Photo det side).
M.
