William P Hilmes
- May 10, 2018
- 17
- Joined
- May 10, 2018
- Messages
- 17
I need to build a waveform amplifier to amplifier a sine wave generated by my DDS Signal Generator (Model JDS 6600). The input signal is 12 volts and 100 m Amp. The amplified signal needs to be 3.0 Amps at 12 volts to power a 33 watt electromagnet. I believe I need a non-inverting Op-Amp to do this job. But I am not sure which Op-Amp to use or how the other component of the circuit are designed. I would like to have a variable resistor at the at Rf position to have more control of the output Amp. An output Amp meter would give me more control to prevent overloading the circuit and destroying my electromagnet. Any ideas or suggestions would be appreciated. Thank you!
