which differential amplifier can i use to amplify a low voltage input
Discussion in 'General Electronics Discussion' started by lordmag, Nov 27, 2011.
  1. lordmag
    lordmag
    11
    Nov 27, 2011
    hi ,
    here i want to measure the current Im by using a shunt resistor with low value to have this measure i should amplify the voltage between this shunt resistor so we have a low differential input voltage
    In my application system the output voltage must be between [2v , 10v] so which amplifier can i choose to solve this problem and thank you for help :))
    [​IMG]
  2. OLIVE2222
    OLIVE2222
    690
    25
    Oct 2, 2011
    Hi lordmag!
    TI make a large range of instrumentation amplifiers. The right model will depend of the needed gain (according to your shunt value and the to be measured current) , the offset and the supply. Here under a filtered results with single supply types:
    http://focus.ti.com/paramsearch/doc...og&familyId=1612&uiTemplateId=NODE_STRY_PGE_T
    Many tend to be SMD devices, but super cheap SMD/trough holes adapters are available on Ebay.
    You can also have a look on Analog devices site.
    If your shunt is ground referenced a classic Op-amp can be used.
    Olivier
  3. lordmag
    lordmag
    11
    Nov 27, 2011
    thank you olive ;
    i m still newbie in electronic :) this is my schematic in the attach file
    the problem here ; can you give me same reference amplifier that amplify me the voltage from a low voltage ( U chute ) to an out voltage ( Vs2 ) between [2v,10v] ?
  4. BobK
    7,682
    1,688
  5. lordmag
    lordmag
    11
    Nov 27, 2011
    thank you Bob !!! :))
    i will try it
