K
kyujin
I'm trying to drive a 10ohm load with 20Volts using a MOSFET.
I want the load to be grounded, so My Vs would be around 20volts, so I
need my gate voltage to be at least 25Volts or more.
So I got a ISL6801 High side mosfet driver, hooked up everything as
depicted in the datasheet.
http://www.intersil.com/data/fn/fn9087.pdf
But I'm not getting a output voltage that is 25Volts, instead below
20Volts.
What am I doing wrong?
I hooked up a function generator with 5Vpp with frequency changing from
1Hz to 1kHz.
I'm using Vcc of 5Volts, which is connected to VB via diode. 22uF
capacitor between VB and VS.
i'm not sure if I'm not understanding the circuit very well, or if
there is something that I didn't do.
Help!
20Volts.
1Hz to 1kHz.
Help!
