Mosfet driver ir2112 circuit high side is not working
Wasif
Sep 29, 2017
13
Sep 29, 2017
13
I am working on grid contected inverter for my final project for this I'm making h bridge but low side of mosfet driver is working properly but there is no output on high side can any one help me with this..
Regards
Wasif
Alec_t
Jul 7, 2015
3,591
Jul 7, 2015
3,591
The mistake is that you haven't provided anywhere near enough information. We're not clairvoyant. A schematic would be helpful.
Wasif
Sep 29, 2017
13
Sep 29, 2017
13
vcc is 12v
vd =5v
cap = 1uf
i am giving pulses to obtain output but Ho is constant 5 v
Alec_t
Jul 7, 2015
3,591
Jul 7, 2015
3,591
Where's the rest of your circuit? HO won't rise to the correct bootstrapped level unless VS gets pulled up by the upper MOSFET. With the circuit as shown I would expect HO to be pulsed at 12V, not a constant 5V.
Minder
Apr 24, 2015
3,478
Apr 24, 2015
3,478
Agree, you need the rest of the H bridge for results.
M.
Wasif
Sep 29, 2017
13
Sep 29, 2017
13
thanks for clearing me. i have practically try complete bridge but its not working. that's why i want to separately check the mosfet driver what type and value of bootstrap cap you suggest. and what is the difference between ir2112 and ir2110.
Wasif
Sep 29, 2017
13
Sep 29, 2017
13
I am using low voltage 24v instead of high voltage 320v on mosfets h bridge will be same for both voltage level or you suggest any changes
Wasif
Sep 29, 2017
13
Sep 29, 2017
13
Thanks for suggesting a wonderful blog It clear my all concepts about mosfet driver. Please tell me one thing That I have mosfet driver ir2112 instead of ir2110 can I use it?
Minder
Apr 24, 2015
3,478
Apr 24, 2015
3,478
There is not alot of difference the ir2110 has a little better output drive current as well as being somewhat faster.
M.
