Help with two wires please
Martziniuk
Jan 23, 2022
8
Jan 23, 2022
8
So I managed to pull two wires out of a night vision push button on/off with three stage light IR dimmer.
I know the blue is neutral but which hole does it belong and which hole does the red wire belong.
Thanks for any help, it’s very frustrating and I don’t want to guess.
Martziniuk
Jan 23, 2022
8
Jan 23, 2022
8
I can’t seem to post more pics but from the right the wires are yellow, blank, blank, green, red. where the blanks are either blue or red
Martziniuk
Jan 23, 2022
8
Jan 23, 2022
8
hi ya and welcome :)
without further info ... all anyone here would be doing is guessing
Thank you.
I’ve asked the manufacturer for clarification on where the wires go, can’t imagine they’ll be that forthcoming but I’ll go from there.
4,956
4,956
Try posting another picture keeping it below 300Kb. But vey clear and focused. Other side of board might be helpful.
I take it that the blue and red go to batteries?
Martin
Martziniuk
Jan 23, 2022
8
Jan 23, 2022
8
The two wires that have pulled out are pins 1 and 5 in the plug.
Externet
Aug 24, 2009
892
Aug 24, 2009
892
On your image with arrows marked; the left arrow supplies one side of voltage to both LED indicators. The right arrow connects to the push switch.
If unable to discern beyond, try to sketch a schematic for the traces corresponding to wires 1 and 5 on the plug. Perhaps one is connected to common ground or battery (-) The other may be (+) to the switch. Check very magnified if the anodes or the cathodes of the dual LED are the joined. They have a tiny identifier on a corner.
If the cathodes are the joined terminals on the LEDs, tells the battery (-) connects there, whatever the wire color.
Mark now! the other wires colors location before they break-off too.
Martziniuk
Jan 23, 2022
8
Jan 23, 2022
8
The blue is a negative as it says on the main board connector in the picture. I will have a very close look later to see what’s written in the cathode. Thank you so much for your help
Martziniuk
Jan 23, 2022
8
Jan 23, 2022
8
I’m afraid I failed to read any numbers, this is as close as I could get, even with a magnifying glass.
Martziniuk
Jan 23, 2022
8
Jan 23, 2022
8
Update.
The manufacturers were useless and wouldn’t release any info on which way the wires went. I decided that the right side of the board was a red positive which went through the led so decided it needed the neutral on the exiting side. It’s all working again now,
Big thanks to Externet for his advise.
