Greg Davirro
- May 21, 2017
- 5
- Joined
- May 21, 2017
- Messages
- 5
I have 2 Popcorn Hour A200 Media Players that both had power supply failures at just about the same time. They both have the original power supply/cord/AC-DC adapter. When I plug in to the PCH, sometimes they will power on but if I rotate the cylindrical plug to the back of the PCH, the power will go on and off (based on the lights and fan going on and off) I have sprayed contact cleaner into the socket with no change. It's strange, if I wiggle the cord nothing happens, but if I rotate the connector the PCH powers on and off. Does this sound like a power supply failure or something else? Also, I'm a little confused. Are the "power supply" failures the AC-DC power cords that are failing, or is there a power supply inside the box that is failing, or both? (Photos Attached of inside PCH and power converter)
Thanks in advance.
Thanks in advance.
