Truckdrivingfool
- Sep 30, 2012
- 33
- Joined
- Sep 30, 2012
- Messages
- 33
A few years ago I hung 11 cheap shoplights in my shop and life was great. Then in the time span of a month 10 quit working. I figured cheap lights=cheap caps so I tore into one and found a swollen cap to back my theory and ordered some new caps. The first three went smooth, numbers 4, 5, and 6 weren't resurrected after the capectomy so I started looking harder and found a fuse that was blown on all three. Number 7 I checked the fuse first (was good) and proceeded with the cap replacement to bring it back life. Number 8 - Fuse - good, replaced caps, light still no work, recheck fuse - bad. Took it a step further and jumpered across fuse - Instantly popped newly replaced cap.
New caps installed to the same polarity as the old ones (matches the printing on the board too), so I know that its not that. The pcb in the lights have nice wide traces so I didn't cause any kind of solder bridge. I don't see anything else absolutely/obviously wrong or looking fried.
Is it possible they had a bad day at the cap factory and I got a bunch that are somehow absolutely marked and pinned backwards?
What else would cause the fuse to blow by simply replacing the caps?
