Can someone help me figure out what i'm looking for?
Discussion in 'General Electronics Discussion' started by TacticalJHP, Jun 11, 2014.
  1. TacticalJHP
    TacticalJHP
    6
    Jun 11, 2014
    Hello,
    I'm looking for a specific piece of tech. No idea what it is called.
    It is about the size and shape of a quarter, and it has two wires coming out of it.
    I try to explain it to the guy at radio shack, but he gives me a look like i'm speaking german.
    Does anyone know what i'm talking about?
  2. duke37
    duke37
    5,364
    772
    Jan 9, 2011
    Nein
  3. (*steve*)
    25,501
    2,841
    Ah, ich weiß, was Sie wollen. Es ist ein Viertel-Dollar mit zwei Drähten aus dem Gerät kommt.
    Sie sind sehr schwer, hier zu bekommen, aber zum Glück habe ich eine Sammlung von Quartalen.
    Welche Art von Quartalen, die Sie verwenden? Dies ist sehr wichtig!
    KJ6EAD, Supercap2F and davenn like this.
  4. davenn
    davenn Moderator
    13,948
    1,990
    and what is it supposed to do ? .... ie. what's its purpose
    I could give you a button battery that size with a couple of wires off it, but it probably isn't what you want ??
    cheers
  5. TacticalJHP
    TacticalJHP
    6
    Jun 11, 2014
    It is to be put in a small spot and the wires connected to a battery box to complete a circuit and give a charge.
    the piece of tech i'm describing has a separated positive and negative side, so just a piece of metal wont work for what i need.
    Actually, a button battery with wires is pretty close, accurate description.
    For everyone else, danke.
  6. TacticalJHP
    TacticalJHP
    6
    Jun 11, 2014
    It's not a capacitor, and it's not the flux capacitor. I'm not trying to build a time machine here. (if i did, i would go back and buy a couple of these things when i saw them before)
    it would be more like a connector for a battery box.
    The button battery with wires description really stuck in my head...
  7. davenn
    davenn Moderator
    13,948
    1,990
    OK guys
    the joke has gone far enough
    I have deleted a bunch of posts as a tidy up of the thread
    lets stick with the problem
  8. davenn
    davenn Moderator
    13,948
    1,990
    hi TacticalJHP
    as much as I want to help, without an actual description of what this device is or what its specifically supposed to do
    it's really difficult to offer any good response ( hence the comical responses from some )
    when someone reads ....
    you have to understand how totally vague that is.
    Have you actually seen one of these devices and want to replicate it ?
    if so, where ... give an internet link so we can see what it looks like
    without something specific information to go on, there isn't much I (or anyone) can do to help
    you say a button battery is sorta close .... so this thing supplies power to something else rather than being supplied with power ?
    if so, what do you want to power with it ?
    regards
  9. TacticalJHP
    TacticalJHP
    6
    Jun 11, 2014
    Yea, i understand it is really vague. And i apologize. I'm not the best at describing things.
    I have seen these devices before, but i don't have an Internet link to them. If i did, i would just order a bunch.
    A button battery is VERY close to size and shape. It transfers power from the battery box (which is separate, connected by wires) into the device.
    It just has to power some LEDs. But the space inside the device is limited, so the battery box has to be outside.
  10. (*steve*)
    25,501
    2,841
    Are you talking about a driver board that connects to a battery then a high power LED?
    Or are you talking about power transmitted *wirelessly* from the batteries to the LEDs?
  11. TacticalJHP
    TacticalJHP
    6
    Jun 11, 2014
    did some searching on driver boards, and i don't think that's what i'm looking for, but i think i might have found something else that will work out in place of what I was needing.
    Thanks. One never knows how an idea will bloom.
  12. BobK
    7,682
    1,688
    Why are you so cagey about the function of this thing? If you want one, you must surely know what it does, or at least, what it will be connected to. Why not tell us?
  13. TacticalJHP
    TacticalJHP
    6
    Jun 11, 2014
    "Cagey?"
    I didn't think so.
    I didn't expect to have to submit pictures of my project or draw a diagram of it either.
    All i asked was help with identifying one piece that i did not know what it was called so i could order them. Apparently, this was such an absurd request to be met by German jokes.
    Since i have found a work around for my project, thanks to *steve* mentioning driver boards, I'm no longer needing your help.
    Thank you.
  14. BobK
    7,682
    1,688
    Well, you expect wrongly. We often require both of those in order to help someone. Look at some of the other threads in the forum. In any case, you were much less forthcoming than that, you did not say what your project is.
    If you had said, "I am making an LED flashlight, and I need the little round board that goes between the batteries and the LED", which is what Steve's crystal ball told him, we could have been of more help.
    KJ6EAD and Supercap2F like this.
  15. (*steve*)
    25,501
    2,841
    My first thought was that he was making a throwy, then a torch, now I have no idea.
    I love these guessing games.
    By the way, TacticaljHP, you got the German because the guy in in Radio Shack was probably absolutely justified in his response if you told him no more than you told us. I would have said you were speaking gibberish, except that (a) you said so little that you were effectively saying nothing at all, and (b) Google translate doesn't do gibberish.
    I'm not sure if your project is "Sooper Secret" and you can't tell us, or if you just don't know what you are doing. Either way it becomes really hard to help.
    And now we have 15 posts with a total information content of zero.
