A
amdx
Hi guys,
I want to know if this is a switching supply or a linear regulator.
http://www.monstermarketplace.com/Electronics/Landing2900a2344.html
http://www.amazon.com/PHC-2200W-PHC-2200W/dp/B000VA359W
This involves running a pump, a thermostatic controlled circuit switches
on the PHC-2200w and that drives the pump.
Have had a problem with the thermostatic controlled circuit and
manufacturer
says,
" If you want to run a DC pump via a power supply that "our circuit" powers,
then it should not be a switching power supply."
So trying to figure out if this is the cause of the
failed thermostatic controlled circuit.
Mike
manufacturer
says,
Mike
