Hi forum friends,
This is my home AC sliding gate controller which has been working faithfully since year 2012.
Few days back, when i press the button on the remote control to open, the gate opens full length with no problem but when i press the button again for closing, the gate stops at halfway and doesn't move. If i pressed the remote control, the gate will opens full. Then the process repeats itself again and it just doesn't close full properly. Also, there is no obstruction on the gate rail.
When i checked the controller board, i didn't notice any burn parts or anything unusual.
To assist in diagnosing the board, there are 19 green pins on the bottom section for wire connection.
Pin 1 and 2 are for the ac live and neutral.
Pin 3~5 are for the motor wire common, left and right.
Pin 6 and 7 are not used.
Pin 8 and 9 are for ac power 24v.
Pin 10 is not used.
Pin 11~13 are for limit switch common wire, close and open.
Pin 14 and 15 are for manual push button switch inside the house
Pin 16~19 are not used.
Appreciate anyone with knowledge or past experience in diagnosing this type of board to share and help to bring back the board to its full use. Thank you.
Pin 10 is not used.
