Joe G \(Home\)
Hi All,
Background
I have a little bit of RF and electronics experience and I was called to my
friends house to help fix the HDTV signal problems on ABC(HD). The
complaint was poor signal or no signal and some pixelation (spelling). [I'm
no TV expert].
How could ABC(HD) be poor and the other HD channels and SD channels be OK?
Hmmm I said.
When I turn on the VCR and or the DVD player etc the pixelation got worse
, but most significantly on ABC(HD).
Ahhhh I said, it must be the switch mode power supplies causing
interference.
The problem had recently occurred over the last few months.
- Setup External Analog TV antenna and 2way splitter to another room (all
HDTV signals good in the other room)
Connection
The setup had a Belkin surge protector that protected the RF and mains
power.
Hence the antenna RF signal when through the surge protector (probably
arrestor inside).
Theory
I thought that since the interference was worse with other power devices
on... I suspected that the RF surge arestor must be
coupling noise/interference in to the RF of the HDTV TV set.
Removing /bypassing the RF surge protection ..... all signals including the
ABC(HD) GOOD ! ;-)
==> Problem Solved <==== (I think - but no RF surge protection).
Comment
Perhaps the signal level to the HDTV set was marginal and the extra
interference triggered a threshold level of noise/interference.
QUESTIONS
Q1
Are digital TV antenna significantly different to Analog TV antenna's in RF
pass bands etc?
Is more signal gain required for digital?
Q2
Can you suggest any HDTV forums that might focus on Melbourne?
Q3
What are your comments about RF surge protection (and earthing etc). Is it
really necessary.
Surely the HDTV set has internal surge protection (it's a well known brand
P..c).
Q4
Do you have any clues , comment or tips you can share?
I welcome your comments.
Thanks in advance
Regs
Joe [not a TV expert]
Background
no TV expert].
Hmmm I said.
interference.
Connection
power.
arrestor inside).
Theory
ABC(HD) GOOD ! ;-)
Comment
QUESTIONS
Q1
pass bands etc?
Q2
Q3
really necessary.
P..c).
Q4
Thanks in advance
Regs
