Hello D from BC,
There are three things; Creepage, corona and distance through air.
According to "Reference data for Engineers" (Newnes):
Break down voltage for uniform E-field in air at sea level and room
temperature is 75kVp/inch, 30kVp/cm. Valid up to 300 MHz, use a safety
margin.
So you should evaluate the worst-case field strength for your
application. Highest field strength will probably occur at an air/
insulation transition on thin wire.
Corona discharge
When corona discharge occurs at an air/insulation transition,
frequency comes in play. High frequency will give higher corona effect
and erosion of the insulation will go faster. When the insulation
finally breaks down (under emission of material), the eroded material
helps to lower the air breakdown voltage significantly. A nice smooth
sounding arc will occur with nice smoke and color effects (I played
many times with that [with plenty of water nearby in case of fire]).
Also with high frequency, the zero voltage transition is too short to
extinguish the arc.
I use an RF receiver with high pass filter to search for corona
discharge in HV circuits.
Creepage is another thing. An arc is formed by miniscule discharges
over a (polluted) surface. Here evaporated material also helps the
ionization process to establish and maintain the arc. 300Vp requires
about 1.1mm insulation between traces on an uncoated PCB (functional
insulation, not safety insulation).
When breakdown of a barrier involves a safety hazard, there are
minimum requirements for distance trough air (clearance) and distance
over surface (creepage). Here transient over voltage must also be
taken into account (4kV for 230V mains building installation
equipment) and the type of insulation system (basic or double/
reinforced). To read more for free, go to
http://www.ecma-international.org/publications/standards/Standard.htm.
Go to ECMA287 it is like IEC950, but then for free.
300V/ 700 kHz does not arc that fast (I used same frequency in a power
circuit). Are you sure that there are no higher transient voltages
present in that waveform? Did you clean the board after soldering,
etc?
Best regards,
Wim
PA3DJS
www.tetech.nl
