EAGLE Schematic and PCB layout software
Discussion in 'Beginner Electronics' started by Chris W, Mar 1, 2005.
  1. Chris W
    Chris W Guest
    I have been working on figuring this software out for a few days now. I
    can't seem to figure out how to tell it that I want Vcc and Gnd for all
    of the chips in my circuit to go to a certain pin on a header. I have
    used the various Vcc and Gnd symbols in the Supply1 library, but still
    the PCB layout doesn't show a connection from the chips to where I want
    them to go. I am using chips from the ttl logic library and those chips
    don't have a pin for Vcc or Gnd in the schematic. In the PCB layout it
    will connect all of the Vcc and Gnd pins from all of the chips together
    but it won't connect it to the header pin I want it to. There has to be
    a way to do this with out manually drawing in a trace. Can anyone here
    help?
    Chris W
    Gift Giving Made Easy
    Get the gifts you want &
    give the gifts they want
    http://thewishzone.com
  2. Use the 'invoke' command to show the hidden pins. The invoke command is
    schematic, right above the T for text. Click it, click the part you want
    to show the power pins for, and you can make it visible.
    You should go through the tutorial. It'll save you time trying to figure
    this stuff out. The user interface for eagle is totally counterintuitive
    initially, but once you get used to it, it's not so bad.
    Regards,
    Robert Monsen
    "Your Highness, I have no need of this hypothesis."
    - Pierre Laplace (1749-1827), to Napoleon,
    on why his works on celestial mechanics make no mention of God.
  3. JeffM
    JeffM Guest
