DVD r/W
Discussion in 'Electronic Design' started by Fernando, Nov 3, 2004.
  1. Fernando
    Fernando Guest
    I am with problem in the installation of a new DVD recorder (LG). If
    somebody can
    to help me, I thank.
    I installed DVD in my computer operating with Windows XP with 512 Mb of
    memory.
    The computer recognizes DVD and to inform that it is working correctly,
    meantime
    it doesn't read or writes any disk.
  2. Chaos Master
    Chaos Master Guest
    (Fernando () IN
    Try to ask in alt.cdrom or alt.video.dvd.
    I don't have a DVD drive on this PC, but have you installed the latest drivers?
    []s
    Chaos Master®, posting from Brazil.
    "When there's nothing left to process, not even a bit,
    the CPU must reset, and 0000:0000 should be hit."
    http://marreka.no-ip.com | http://tinyurl.com/46vru | http://renan182.no-ip.org
    | http://marreka.blogspot.com (in Portuguese)
  3. Tam/WB2TT
    Tam/WB2TT Guest
    Assuming you installed the drivers and software that came with the drive,
    check the jumper settings on the drive. That is, Master, Slave, or Cable
    select.
    Tam
