Your in spades, child.
Whoop-d-doo, I have built IR receivers/transmitters using a PIC, so what?....
So your stupid pig ignorant claim that they all use the DCD on the
serial port and nothing else is clearly just plain wrong, fuckwit.
I have also built complicated things using a PIC and again so what?....
So you've managed to duplicate LIRC, and what for?
Using a whole PC solely for such a simple task is just ridiculous.
Can't you program a PIC?
It does use a PIC, fuckwit. And communicates
back to the PC using RS232, fuckwit.
When you can implement a 1200 baud modem receiver in software on a
PIC to decode the caller-id info and display it on an LCD, and power the
whole thing from phone line leakage come and talk to me about complex things.
Never ever said a word about 'complex things',
you silly little posturing fuckwit child.
I was JUST exposing your stupid pig ignorant claim that
they ALL use JUST the DCD line as pig ignorant drivel, child.
I don't see you posting any schematics.
No need for any schematic when a PIC is involved and
its communicating with the PC using RS232, fuckwit child.
I bet the OP is using one just like the circuit I posted.
Even if she is, you STILL cant just run them
in parallel at the RS232 level, fuckwit child.
Did I say that? no... The one I described (and any that you
are likely to find in the real world) don't use RXD or TXD.
Pity you STILL cant just run them in parallel at the RS232 level, fuckwit child.
And exactly how do you know that?
You dont know what she has, fuckwit child.
When the OP posts a circuit we will see.
Unlikely that she is actually capable of doing that, or she is unlikely
to have needed to ask the original question, fuckwit child.
And as I originally said, the OP can parallel the IR detectors themselves
She clearly said she doesnt want to butcher the current detectors, fuckwit child.
And even someone as stupid as you should have noticed
that they arent anything like adjacent anyway, fuckwit child.
and it will work fine as long as only one is receiving
a signal. You do grasp open-collector outputs, right?...
Yep. Pity we happened to actually be discussing whether its feasible to
RUN BOTH DETECTORS IN PARALLEL AT THE RS232 LEVEL, fuckwit child.
Its absolutely no news to anyone at all that its always going
to be possible to design a new two head IR detector.
I certainly didn't let my imagination fill up the gaping
hole in her description with incorrect assumptions.
No assumption involved what so ever with that last para of hers, fuckwit child.
As I said before, I bet the OP is using a
receiver just like the circuit I posted a link to.
YOU STILL CANT RUN TWO OF THOSE IN PARALLEL
AT THE RS232 LEVEL EVEN IF IT IS, FUCKWIT CHILD.
To assume that the OP is using a complex receiver
capable of decoding the multitude of protocols and
assorted variations/timings is a giant stretch to say the least.
Pity I didnt assume anything of the sort, fuckwit child.
Since you can't feed raw IR to the RXD pin,
YOU ARE ASSUMING this level of complexity
Nope, YOU STILL CANT RUN TWO OF THOSE IN PARALLEL AT THE RS232
LEVEL EVEN IF IT IS JUST USING THE DCD LINE, FUCKWIT CHILD.
and YOU are very likely to be wrong. It's far more likely that the
hardware (purchased or homemade) is likely to be as I've shown
since the DCD (or some other input control pin) is the only
thing capable of responding predictably to the raw IR data.
Now show us all how much you know about serial comms
and explain how raw IR can be fed to an async serial
input pin and sensible information passed to software.
Never ever said you could, fuckwit child.
<reams of your puerile shit any 2 year old
could leave for dead flushed where it belongs>
