16f876 dual serial asynchronous link?
Discussion in 'Hobby Electronics' started by Yoong Ping, Lim, Sep 12, 2004.
  1. Hi,
    i need to have two asynchronous link using 16f876 but it only has 1 usart
    hardware?
    any recommendation?
    thanks
  2. Josh
    Josh Guest
    If your 2 async links can be different speeds, just wire both up in
    parallel, and switch the BRG from one speed to the other to switch
    between serial devices.
    As long as there's sufficient difference between the two speeds, the
    two devices connected won't see the data destined for the other. From
    memory anything more than about 10% difference is pretty safe.
    Last time I did this on a '876 I was switching the usart between 1200
    and 38400bps without any problems. The trick is finding a crystal that
    will allow the baud rate generator to approximate your two baud rates
    accurately anough.
    Josh
  3. David Wilson
    David Wilson Guest
    Try hanging a MAX3100 off the SPI port.
    http://www.maxim-ic.com/quick_view2.cfm?qv_pk=1731
