Categories
Platforms
Content
A triac passes current in both directions on an AC suppy if everything is optimum.
If the system is not quite symmetrical, then current can be passed in one direction more than the other. This can cause the transformer core to saturate and current will not be limited by the transformer inductance. BOOM.
I made a transformer based supply to heat a hot wire cutter. I put an incandescent light bulb in series with the transformer primary to limit the current, this worked well and the brightness of the bulb was a help in setting the voltage. This was much cheaper and lighter than a Variac.
A TRIAC has a minimum voltage drop across it that can be 2 V or more even when the dimmer is set to 100%. If the triac is in series with a low voltage secondary, that voltage drop might be a problem for whatever is downstream. If the TRIAC is in the line voltage primary, then a possible problem is the voltage wave distortion created by the TRIAC turning off and on every half-cycle of power line. Remember, a TRIAC does not "turn down" the input sinewave, it truncates it. This reduces the input wave's average value, and the thermal mass of an incandescent light bulb acts as a lowpass filter so you do not see anything other than a dimmer bulb. But the AC voltage waveform is severely distorted, and has the same peak value as an un-dimmed waveform even when at 50%.
At its heart, a TRIAC dimmer is designed and built to do one thing - dim an incandescent light bulb. Everything else has potential problems. Not unsolvable, but something to keep in mind.
ak
A transformer run on AC sine wave has the magnetic flux varying from one direction to the other. The average flux is zero.
The triac will be turned on by a diac and if this is perfectly symmetrical, the positive and negative parts of the waveform will be identical and the average flux will be zero. If however the positive and negative pulses are not equal, then there will be a net flux in one direction with the possibility of core saturation.
Is this a common failure in the real world?
In practical terms, would this mean extra heat, or short transformer life, or another issue? Is this a common failure in the real world?
