Iuval Clejan
- Sep 28, 2017
- 3
- Joined
- Sep 28, 2017
- Messages
- 3
Are there any such on the market? If not, why not? I am calculating that to dim 100W incandescent bulb with 120V AC from 0 to 0.9 the voltage, a variable capacitor on the order of 0-230 uF is needed. Are there no reasonable size variable capacitors available in that range? If we only needed to dim from 0 to 0.5 the voltage it would be 0-66 uF. And if we need to dim a 10W bulb it would be 0-6.6 uF. I know there might be issues with non-purely resistive loads such as CFLs or LEDs? Same question for inductive voltage dividers...
