Jacques Carrier
Hi fellow techs,
These 27" Sony and Panasonic DIGITAL TV's work fine with Cable
TV.(Videotron here in Montreal).
But the reception is very bad if I use a rabbit ear antenna
(snow,diagonal and sinusoidal fine lines).This distorsion is very
apparent on low VHF channels.
I realized that this distorsion is caused by the digital TV which
radiates in the air and this distorsion is fed back into the tuner by
the rabbit ear antenna.All nearby TV's will show the same distorsion
as long as the digital TV is turned on and within about 25 feet of
other TV's.By the way all analog TV's work fine with rabbit ear
antennas.
The only solution I have found so far is to use a 25 feet RG-59
shielded cable
connected to the rabbit ear antenna.Not very practical when I want to
fine tune
the reception on any given channel!!
So it seems that DIGITAL TV's are meant to be used exclusively on
Cable TV.
This was confirmed by the Sony service manager here in Montreal.The
reception
is also very bad if I use an outside antenna.
Please let me know what you think about this situation.
Best regards,
Jacques
antennas.
shielded cable
fine tune
Cable TV.
reception
Best regards,
Jacques
