A
Andrew
Hello,
I recently tried to use a Sharp PC3Q67Q photocoupler in my design. It
is digikey part number 425-1360-1-ND.
I am trying to use a 0-5V PWM input at 10kHz to the diode through a 500
ohm resistor (also tried 200 ohm resistor, same results), and have the
transistor output switch 12V.
The trouble I am having is that the PWM signal shows up across the
diode (pin 1, ref pin 2), but the output is strictly 12V. It seems
that the photocoupler is not able to switch at 10kHz? It does "blip"
and "dip" at a frequency of 10kHz, indicating that it is trying to
perform a square wave. This was with a 100k pulldown resistor. With a
lower pulldown resistor (3k) I was able to really see the output of the
photocoupler try to get to a square wave. The rise time is decent,
although not nearly square (roughly 6uSec), but the fall time is very
very slow. This causes the output to not be a square wave at all.
I'm not sure how exactly to solve my problem. It seems that the
rise/fall rate of the output transistor is too slow? I forget the
exact fall time value that I measured, but it was approximately 30uSec
(larger than the claimed 18uSec). I suspect this is because the 3k may
be still too large of a pulldown resistor? I did try a 1k before the
3k and that was worse. It was still not a square wave, and did not
work as well as the 3k. The claimed rise/fall times from the spec
sheet of the photocoupler were with a load of 100 ohms. I could try
this, but I am wondering if it is even worth it. Is it possible to
achieve a nearly perfect square wave on the output side of this
particular photocoupler?
So, basically, if not, I am wondering how to select a photocoupler that
is able to switch at this frequency? I COULD use a regular transistor
if I had to, but I would like to use a photocoupler still. At first I
had just looked at the max rise/fall times as being 18uS/18uS
respectively, and figured that this would allow a maximum operating
frequency of 27.77kHz. If this were, true, I wouldn't think I should
be having a problem switching at 10kHz.
Does anyone know why I am having my trouble, and what I might do to
learn more about selecting these products in the future?
Oh yeah, each output is driving 2 IRF1405 (IRF1405-ND) MOSFETs, well,
the gate of them anyway. That is what the pulldown resistor is for. I
did disconnect the gate from the circuit and just did a pull-down
resistor to ground with the same results, so I doubt this is the
problem!
Thanks alot for any suggestions,
Andrew
problem!
Andrew
