Using MIL-HDBK 217F to determine FAILURE RATE OF led
jacksona
Nov 8, 2021
Nov 8, 2021
I'm trying to figure out the failure rate of an LED using the mil-hdbk217F .
The problem that I have is there is no category for an LED in the diode section. I was thinking of using the general diode category, but the calculation requires the max voltage / applied voltage.
With an LED it's about how much current not voltage so I'm a bit stuck
Bluejets
Oct 5, 2014
6,937
Oct 5, 2014
6,937
Not much point as any driver will fail long before the LED. (Practical experience)
Harald Kapp
13,738
13,738
Try this.
Section 6.1 of the MIL Hdbk states that voltage is diode reverse voltage:
This is not applicable to LEDs as these are operated in forward mode only (at least that's how it should be).
Since "voltage applied" in reverse is 0, the voltage stress ration VS = 0, thus πS = 0.054:
The relevant factor is temperature stress which can be calculated from the other tables in the Hdbk , the power dissipation of the LED, the thermal resistance of the LED and ambient temperature.
Good point but doesn't help if one is required to deliver a calculated MTBF value for a product.
dave9
Mar 5, 2017
1,188
Mar 5, 2017
1,188
Tell that to my landscape lights. The LED bulbs are rated for automotive use (so should be good up to 14-ish volts) but much about 12V their lifespan is only a few hundred hours due to having only 2 x series resistors to limit current. I ended up putting a buck regulator board in series.
dave9
Mar 5, 2017
1,188
Mar 5, 2017
1,188
^ If not for being generic-Chinese, the bulbs would cost about what an entire new landscape light set cost.
These generics, it was a wacky promotional deal, buy a 20 pack of something else, get these thrown in free, but instead of one ten pack free, I was sent 10 x 10 packs free (seller didn't want them back, return shipping must exceed their loss), plus a pair of fog lights were free with that 10 pack product, so I ended up spending $10 for 120 T10 bulbs and 20W fog bulbs. The buck driver board to fix the issue was only $4 from a US shipper.
