Determine no. of '1's in a 4-bit input
circuitforfun
Oct 16, 2013
3
Oct 16, 2013
3
When given a 4-bit input, determine whether the number of '1's in the input is odd or even. For example, if input is 0110, output is 0. if input is 0111, output is 1.
(a) simplify the Boolean logic expression using K-map.
(b) draw the digital circuit using only NAND gates
I tried to draw the truth table and then express the logic expression in sum-of-product form:
A'B'C'D + A'B'CD' + A'BC'D' + A'BCD + AB'C'D' + AB'CD + ABC'D + ABCD'
I tried k-map but it cannot be simplified. Is there anything I can do to simplify it?
Hope somebody can help me with this. I would be very thankful if somebody could help me. Thank you for your attention. Look forward to your reply.
Laplace
Apr 4, 2010
1,252
Apr 4, 2010
1,252
What if you did a K-map in stages? For example, do a map for A & B, then another one for C & D, then combine those outputs together into another map.
circuitforfun
Oct 16, 2013
3
Oct 16, 2013
3
Thank you for your reply. But when I split the k-map into 2 stages, each function cannot be further simplified as well.
I wonder if my approach in the beginning is wrong. Should I treat each bit as input A,B,C,D respectively? Is there any other way to do this question?
(*steve*)
¡sǝpodᴉʇuɐ ǝɥʇ ɹɐǝɥd
25,510
25,510
Perhaps you should draw up a simple truth table for a pair of bits.
Then imagine you do this for two pairs of bits and draw up another truth table to generate the overall output from these two intermediate outputs.
Now see if you notice anything...
circuitforfun
Oct 16, 2013
3
Oct 16, 2013
3
Do you mean each pair of bits (2 bits) form a relationship of XOR (Exclusive OR)?
(*steve*)
25,510
25,510
That would be a great observation.
What about how you combine these exclusive-or-ed outputs to get a final result?
Exclusive-OR is not handles well by kernough maps. You kinda just have to recognise them. See here.
Laplace
Apr 4, 2010
1,252
Apr 4, 2010
1,252
FYI: It takes five 2-input NAND gates to make one 2-input XOR gate.
