Tzortzakakis Dimitrios said:
Are you joking?GEARED?Steam turbine?They are on a single-cast shaft.THAT
shaft is expensive, thus it connects the turbine and generator.Imagine a
gear for 2,500,000 hp (usual power of a nuclear plant generator).The
generator and turbine are designed to run at the same speed.Even train
locomotives use diesel-electric transmission, and the traction motors are
directly coupled on the wheels.So must be happening at the ships, too.
Hate to burst your bubble, but they *do* make gearing for this kind of
power. Typical steamships use reduction gears between the IP/LP turbines
(in thousands of RPM) and the main shaft (hundreds of RPM). And smaller
gearing between the HP and IP turbines. Bull-gears, the final output gear
connected to the propeller shaft are large with double helix cut. Often use
double-reduction with 'quill' shafts between successive gear stages.
Saw more than one bull gear get some broken teeth ground out. Didn't
replace the teeth, just ground down the sharp edges so they wouldn't wear
into the low-speed pinions (some sailors didn't believe the rules about
FOD). Some marine applications include clutches that can carry over 35000
hp. These ain't your standard automobile clutch, they have dozens of
friction plates and positive, splined-sleeve engagement.
Large stationary power plants have the HP and LP turbines co-linear with the
generator, that is true. But the 'shaft' is made up of several pieces, one
for each turbine section and another for the generator. Each section is
bolted to the next with flat-faced, bolted couplings. One plant (I think in
Korea) a year or so back had a failure where a fire in one bearing support
caused it to sieze. The shaft twisted right apart and in the process threw
pieces/parts all around the turbine building. The pictures were *very*
impressive.
Get a couple of mechanical engineers together in a room and they can come up
with things almost as outlandish and exotic as any EE's
daestrom
